Use [Smart Digital Signage Display QB55R] as regular TV
(Topic created on: 27-11-2021 10:55 AM)
TheJesper
Hi, I was just wondering about the Samsung Smart Digital Signage Displays, in particular the QB55R model.
Are there any disadvantages in using this as a regular TV with a connected TV-Box compared to the consumer product TV? Are there any specs that will make it less suited for long hours of watching series or movies?
https://www.samsung.com/us/business/displays/4k-uhd/qb-series/qbr-series-55-lh55qbrebgcxza/
Disregarding the fact that it might be harder to adjust screen, connect old scart units, change volume, changing input and so on... Remote is included though so maybe not an issue...
1 REPLY 1
Signageguru
No smart hub. no TV tuner.
But with the TV box, it is the basically same as consumer TV or even better if a good TV-box.
