Universal remote doesn't work the xbox one x
(Topic created on: 05-09-2020 05:10 PM)
dtwinfield
My xbox one x doesn't connect to the samsung universal remote using the hdmi slot 2. The remote controls the virgin box on hdmi slot 1. The TV is Samsung qled QE43Q60 RATXXU. The remote will not turn on or off the console. When you go in to the settings it does not give an option for the xbox one x only the xbox one s
1 REPLY 1
MarcosG
It's sad the Samsung doesn't even try to answer.
