Unable to navigate settings - check that One Connect is connected
(Topic created on: 08-10-2017 09:17 PM)
Nixstrom
I've just bought a 65" KS8005, and we've spent a good day attempting to set it up.
It keeps showing the error "Check that the One Connect is connected to the TV". If I unplug the One Connect and plug it back in, I will actually briefly get the menu. When I finally discovered that, I was able to update the formware.
However, after doing that, the remote is now unresponsive. I will still on occassion get the menu when unplugging/plugging in the One Connect, however I am unable to navigate the menu.
The problem doesn't seem to be the remote. It does recognise some keypresses (namely power off), however I cannot use navigate the menu. After a brief period (perhaps 15 seconds), the menu will disappear, and only way to get it back is to unplug/plug in the One Connect until it reappears.
We tried plugging a Chromecast into the One Connect – it does recognise that something is connected, and I can attempt to cast to it from my devices (they will just never connect).
We tried changing the cable also, that didn't help with the issue.
Tags (2)
1 REPLY 1
Sunny530
I have the exact same problem with the same model tv. Please tell me if you found a solution. I can use a keyboard and hit the tab key i also used the voice control to enter the settings menu but i am unable to select anything if i hit enter on the keyboard it causes the tv to exit the menu and switch to the samsung tv app. I cannot use the directional circle to navigate
