UHD settings and HDR+
(Topic created on: 13-11-2018 04:45 PM)
Brynsta
So recently got the Samsung NU8070 and it’s very good but not sure on a few settings to get the best out of it, I have a PS4 Pro and Sky Q both have UHD and HDR content, but when I select HDR+ the screen almost gets a green tinge to it? Like the white menu is an off white and so forth, I have it displaying in UHD as when you select the source it tells you the resolution in the top corner but HDR+ doesn’t seem to have any any benefit? What do you guys have on in terms of screen settings for best picture?
11 REPLIES 11
AndrewL
Hi @Brynsta
Firstly I recommend going to Home > Settings > General > External Device Manager > HDMI UHD Color > On. This will convert the TV's HDMI connector to a mode optimised for the UHD 50P/60P signals. Do this for all relevant HDMI inputs, then check the settings on your Sky Q and PS4 Pro to ensure that they are set up to output in UHD.
NikyWu
Hi - been puzzling with this one for a while. for me switching on HDMI UHD Colour results in the Samsung TV not being able to detect the sky a box. Switching it off and the box is detected again...
should this work with the sky Q V2 box?
JAMES4578
Samsung Members Star ★★★
Hi @NikyWu  Just checking you have the latest firmware on both the Tv and sky Box? If not download it,Tv can be updated via  USB.     If updated and still isues you could try a Factory reset to see if that makes a difference.
I have Skyq V2 and do not have this issue, though am aware that some issues with V2 Box and Samsung TV (though mostly concerning Box going into Standby) .
Bobby76
Pioneer
Hi, my opinion based on my 55" Q9F is as follows:
My set up is:
Nothing connected to the one connect box except HDMI 4 which goes to my Dennon X3500 amp.
Plugged into the amp I have a 4k BT vision box, a Now TV stick, a 4k Amazon Fire Stick and an Xbox One S as a 4k bluray/games. I run Netflix and all catch up channels through the xbox because it does Dolby Atmos for everything, either simulated or Native. I control all my devices using a Harmony Elite.
For the TV picture settings, the following is most satisfactory for me for all sources through the amp at any time of day including games, sports, action scenes etc:
Backlight 30
Brightness 0
Contrast 50
Sharpness 5
Colour 25
Tint 0
Digital clean auto
Auto motion plus off
Local dimming high
Contrast enhancer low
HDR+ mode ON (turn it on first then adjust everthing)
Colour tone warm2
Gamma ST.2048 (its designed for HDR modes)
ST.2048 = 0
Rgb only mode off
Colour space Native
ECO solution, everything off except auto power mode (turn this off if you plug a hard drive in for recording)
One other note, the scale used for the settings varies between models of TV.
Examples on my tv:
Backlight max is 50
Brightness min is -5 max is +5
Contrast max is 50
Sharpness max is 20
Colour max is 50
Tint min is g15 max is r15
So to translate between different sets I work on percentages instead of absolute numbers and judge how it looks from there. Everyone's different so there is no right answer, but these are what work for my mid 40's eyes!
Hope this helps!
NikyWu
Thanks will give it a whirl
Bobby76
Pioneer
Hope it works well for you. If you find it too bright, leave everything as is and just turn the backlight down. I found 15 to be excellent at night but too dark in full daylight. I settled at the higher level as the best all rounder for me.
JM01
My set up is:
Backlight 30
Brightness 0
Contrast 50
Sharpness 5
Colour 25
Tint 0
Digital clean auto
Local dimming high
Colour tone warm2
ST.2048 = 0
Rgb only mode off
Colour space Native
Examples on my tv:
Backlight max is 50
Contrast max is 50
Sharpness max is 20
Colour max is 50
Hope this helps!
Hello,
Would these settings work on the: Samsung QE65Q90RATX?
Thank you.
Matsol
hi. I have a UE48JU6400. I have turned on the UHD colour mode but my sky box will still not recognise it as 10 bit colour. Any ideas?
JAMES4578
Hi@Matsol , According to Display Specifications this model's display is 8 bits, some models are 8 bits + FRC  (frame rate contol)  and others  10 bit.  https://www.displayspecifications.com/en/model/0ba827a    Whilst has got 10 bit on Rtings they say state that when consider 8 bit with dithering to be equivalent  https://www.rtings.com/tv/reviews/samsung/ju6400  More explained here https://www.isolapse.com/true-10-bit-vs-8-bit-frc-monitor-what-is-the-difference/
10 Bit setting on Sky does work if you have 8 bits+FRC but will not be true 10 Bit Colour.
