UE82NU8002T pip sound output only to tv repro
(Topic created on: 28-11-2020 08:55 AM)
I have this problem too
Killca_cze
Always when PIP is turned on, it needs to change sound output from receiver on ARC HDMI (home theatre) to TV speakers manually, otherwise there is no sound unfortunately. Is there any way (settings or firmware update) to have PIP source sound in home theatre?
Example: playing on xbox and the rest of family might watch tv in PIP window using home theatre.
3 REPLIES 3
Mickessounds
Sounds good will have to try it the Wen the Wife finishes watching here faver favourite program Michael thank's
Mickessounds
Hi,Kill_cze have a newish tv & a very old pioneer twin cd player with Radio twin tape player & Karaoke Player it will Play Karaoke & CD but it sounds as if the tracking is out!!
Killca_cze
I do not understand, if i am right, i guess, my problem helped you to have at least some sound, thats good, but still it needs to go through home theatre, not just through tv speakers :smiling-face:
