Go to solution Solved
UE55RU7402 doesn't work with 5GHz WiFI
(Topic created on: 02-09-2019 05:29 PM)
AxlZoli
Pioneer
Hi Guys,
I bought an UE55RU7402 TV and it can't connect to 5GHz WiFi because the TV doesn't see it. My previous TV (MU6102 worked fine with 5GHz WiFi with the same router- ASUS RT-AC53 dual band AC)
The 2.4GHz Wifi works fine, but I need the 5GHz too. According to the specifications the 802.11n is supported, but there is no other info. (supported? where? on 2,4GHz or/and 5GHz?)
Do you have any idea what should I do with this? The latest fw is on the TV (1315.4) Is there any possibility to use the 5GHz WiFi?
Thanks for your support
Best Regards,
Zoltan
RozvM
Samsung Members Star ★★★
Wi-Fi max transmitter power : 100mW at 2.4GHz–2.4835GHz. (Page 19)
So I don't see any chance at all.
Kérlek nyomj a MEGJELÖLÉS MEGOLDÁSKÉNT! gombra, hogyha az adott hozzászólás megoldotta a problémádat. Ezzel nem csak a mi munkánkat, hanem a felhasználók gyorsabb és könnyebb tájékozódását is elősegítheted!
3 REPLIES 3
RozvM
dubbelmacka
I checked the MUSDVBEUR-2.0.7_EM_MUSE_EU_ENG_190628.0.pdf before buying 4 TV's and at page 155 it says:
  • This TV supports the IEEE 802.11 a /b /g /n /ac communication protocols. Samsung recommends using IEEE 802.11n. Video files stored on a device connected to the TV via a Home Network may not play back smoothly.
Can someone at Samsung confirm it has 5GHZ or not?
RozvM
It also says, that
So that's why the BN68-09493C-01_URU7400G_XH_L16_190611.0.pdf exists, with the exact supported frequencies:
