UE50TU7020KXXU Dailymotion cast icon
(Topic created on: 17-12-2020 04:38 PM)
BARKERLAND
I've just bought a new samsung UE50TU7020KXXU
Today to replace my sony bravia smart tv.
I have a samsung A10S phone with Dailymotion app installed.
When I had the sony tv the dailymotion app on my phone had a cast icon at the top to cast it to the tv.
I've noticed though that since I got the Samsung the dailymotion app no longer has this function.
I've tried deleting and reinstalling the app to no avail.
Does anyone have any advice or ideas?.
Thanks in advance
4 REPLIES 4
ashyt16
Navigator
why dont you just use the daily motion tv app?
BARKERLAND
Because the new Samsung TV's dont have it on them
Not in UK anyway.
I've even searched the apps available to the tv and no dailymotion I'm afraid.
From reading older posts on this and other forums it seems they used to have it on them but not anymore.
ashyt16
Navigator
I have a 2019 7 series tv and it's there.
I have just bought my mother a 2020 8 series tv so I'll check that too.
I find it odd that you say its not available on new TV's. for what reason would Samsung remove it?
BARKERLAND
Thanks for the info ashyt16.......I asked currys-pcworld the place I bought it and they said it's not on this range.
If you're 2019 has it then I can only assume they meant the TU7020 range rather than the whole Samsung range. But if that is the case I dont understand why it cant be put on the TU7020 TVs because everything else is on it?.
Be interesting to know if your mother's has it on it.
