17-12-2020 05:05 PM
my hearing is not so good these days. Would it be possible for me to listen to tv on wireless headphones/earphones whilst others can listen to the tv normally?
17-12-2020 06:01 PM
@Lance8: I don't think this is possible unfortunately, as it is only possible to select a single sound output option at a time. If you confirm the model number of your TV, located on the sticker on the back of the device, then I will look into this further for you.
17-12-2020 06:07 PM
17-12-2020 06:29 PM
@Lance8: Further to the advice offered by @Pugs1957 please head to Settings > General > Accessibility > Multi-Output Audio to enable audio through Bluetooth headphones and the TV speakers at the same time. If you head to Settings > Sound > Sound Output > Bluetooth Speaker List, and pair your headphones, then Multi-Output Audio will be enabled automatically. Apologies for the confusion.
