ue22h5600ak Will not connect to wifi
(Topic created on: 09-07-2019 08:17 AM)
I have this problem too
thecurryman
i upgraded my wifi at home with a tenda mw3 mesh system, all other (newer) samsung tv's connect fine, but this device will not connect, saying incorrect password when I try and join the wifi. I have upgraded to the latest software using the file ver 2890.2
any ideas
1 REPLY 1
Countryfolk28
Hi,
im sure you found a solution by now but if not, or like me you’ve just encountered this issue try this.
The 5600 series uses 2.4ghz where as Tenda mesh uses 4ghz by default. Newer tech can handle this no issue. To fix the problem open the Tenda app and enable “smart assistant.” Connect your tv to the WiFi and it should now connect without issue.
This solved it for me so hopefully it will help out other users
