Go to solution Solved
TV source input
(Topic created on: 16-11-2024 11:20 AM)
GuzziBoy
Helping Hand
Hi folks, Ive got a QE55QN95C and a 24in N4300 HD Smart TV. Both excellent (maybe the 24in speaker sound could be better but not major issue). I have a Humax Aura in my living room and use the DNLA facility it has to transfer recorded video to both my Samsung TVs. I just change the Source on the TVs and the Aura shows up and I can play the recordings from the Humax. Mind you they are only broadcast in SD, but thats OK on the 24in Kitchen TV.
My question is if I buy a 2024 43” DU8500 Crystal UHD 4K HDR Smart TV, will it have the same input source capability as my other Samsung TVs. My wife wants to be able to watch her Humax recordings when in the bedroom. Id get my head in my hands if it didn't work. Cheers
lminvti
Samsung Members Star ★
Hi there 👋, as i can see on the spec sheet it is supported 1731758900647.jpg
2 REPLIES 2
lminvti
GuzziBoy
Helping Hand
Hi Thanks for pointing that out. I looked all over that spec sheet and didn't notice it. So thanks, I must be going blind. All good cheers
