TV remote
(Topic created on: 25-08-2023 01:09 PM)
Mike801
2020 samsung smart tv
How to go previous channel on remote. My server is YouTube.
JAMES4578
Samsung Members Star ★★★
@Mike801 on a Smart Remote you should be able to use the Colour coded Button(Red,Green,Yellow,Blue).press this button and select, there should be option for previous channel. others ones are the likes of record and Cable Box You may also be able to bring previous channel up by pressing the return Button for at least one second.     on a standard Remote there may be a dedicated button.
Some information here https://droidrant.com/what-do-the-buttons-on-a-samsung-remote-do/
2 REPLIES 2
JAMES4578
Mike801
Thanks will try.
