TV Blank screen and turns off and on
(Topic created on: 25-07-2022 06:50 PM)
J92
Got a QE55Q700TATXXU just over 12 months ago, I now have sound but a blank screen and it turns off and in repeatedly - I don’t want to lose £1499 !!!   On the SmartThings app it just appears offline all the time, and the remote doesn’t allow me to get to the menu etc
1 REPLY 1
JAMES4578
Samsung Members Star ★★
Hi @J92  Can you try a soft Reset by holding the power on the Smart Remote for around 5 seconds until the Samsung logo appears. does this make any difference?
If not I suggest you power off the Tv and unplug at the wall for 30 seconds before trying again, see if that provides a solution.    If still no joy if issue with external connections have you tried different ports  ,you may need to try different HDMI cables somewhere down the line if there is an issue there.
For more  general troubleshooting see here https://www.samsung.com//support/troubleshooting/TSG01109749/#tv-with-a-one-connect-box-has-no-pictu...
If issues persist you may wish to  contact Samsung Support, contact details here https://www.samsung.com/uk/support/contact/#product-support
One Ui 5.1,Android 13 .
