TuneIn Radio.
(Topic created on: 03-04-2023 08:00 PM)
CrissyWissy
I've just bought BU8000TV, TuneIn Radio is not a pre installed app and it's not recognised when I use the app search feature. Is there a way to get TuneIn?
6 REPLIES 6
JAMES4578
Samsung Members Star ★★
HI @CrissyWissy   if you go to Samsung Apps there are suggested ones, Group Content and Genre.   Tune In radio should be available  within the Lifestyle section of Genre.  Some information here https://help.tunein.com/how-do-i-install-or-uninstall-tunein-on-my-samsung-tv-
One Ui 5.1,Android 13 .
CrissyWissy
Thanks for the reply. It's not there, I've read pretty much all of the posts I can find about it and they all say the same as you but they are all from 2018 or before. I wonder if its been removed from the approved list for some reason.
JAMES4578
oh right, it available on an older model I have anyway (though 2017)
gnc
Get firetv cube
JAMES4578
Tunein have confirmed the app is not currently available on the latest Samsung models. Will update if any information received on timescale for change.
JAMES4578
@CrissyWissy  Apparently the engineering Team is  working on a fix, no not have a definitive answer on how long this will take but  TuneIn think it should be  "soon".
