there is no playstore on my smart TV
(Topic created on: 17-03-2025 07:59 AM)
Mil12
there is no playstore on my smart TV, I tried to find it from 'Apps' and 'Search" but there is no playstore for me to download. My software is uptodate
Model Code: qa65qn85bakxxt
Products mentioned in this post
9 REPLIES 9
AsadM
Hi @Mil12
It sounds like you're using a Samsung Smart TV with Tizen OS, which doesn't natively support the Google Play Store. Instead, you can find an app store called Samsung Apps (or Galaxy Store), where you can download apps for your TV. Here’s how you can access and download apps:
  1. Press the Home button on your remote to open the Smart Hub.
  2. Navigate to Apps (this might be in the "Apps" section or the "Samsung Apps" store depending on your TV model).
  3. From here, you can browse or search for the apps you want to download.
If you're trying to install specific apps from the Google Play Store, you may want to check if there's an app version available on the Samsung Apps Store or use the TV's built-in app store.
Mil12
thank you for the reply!, i don't see Samsung Apps (or Galaxy Store) just the TV's built-in app store or is it the same thing? And if there are no apps that i want in those store are there any other methods that i can download apps from other stores? Thank you for your time and help.
JAMES4578
Samsung Members Star ★★★
Hi @Mil12  Welcome to the Samsung community :smiling-face: Yes it is the inbuilt App store, can see the type of Apps available here  https://www.samsung.com/uk/tvs/smart-tv/smart-hub-and-apps/
Would not recomend installing from  unknown sources, can use an external Device such as Google TV.
Tasha R3n33
There is no search button to search for a specific app. Only "recommended apps" show up. Who has the time to scroll through thousands of "unalphabetized" apps just to find a specific one that I'm looking for? This new update is ridiculous! Samsung should have left well-enough alone. There was nothing wrong with the old way. Trust me when I say that thousands of people are complaining (on other threads) about Samsung TV's new update. I'll probably have to switch TV brands if I cannot access the apps that I WANT to download, or else what is the point of having a TV?
Tasha R3n33
Not true for users in the US. There is no search button to search for a specific app. Only "recommended apps" show up. Who has the time to scroll through thousands of "unalphabetized" apps just to find a specific one that I'm looking for? This new update is ridiculous! Samsung should have left well-enough alone. There was nothing wrong with the old way. Trust me when I say that thousands of people are complaining (on other threads) about Samsung TV's new update. I'll probably have to switch TV brands if I cannot access the apps that I WANT to download, or else what is the point of having a TV?
Tasha R3n33
JAMES4578
Can you access the universal search function as shown in this thread https://eu.community.samsung.com/t5/tv/unable-to-search-or-download-additional-apps-on-samsung-tv/m-...
A bit about US apps herehttps://www.samsung.com/us/tvs/smart-tv/samsung-tv-plus-and-smart-hub/
We are the Uk/Ireland/European communities though.
Daini22
Hi mil12
I dont get the apps and games that need
WrAngel
Yh 2022 QN95B in the UK and they won't let me download any apps at all there is no playstore or galaxy store which I dont understand I believe it must be a regulations issue with the government or something like that which is pretty sh*t because I the UK we pay more for everything and still we get the worse services
