Go to solution Solved
smart t.v will not let me install any thing
(Topic created on: 15-03-2022 06:41 PM)
richiebucky
here
JAMES4578
Samsung Members Star ★★
Hi @richiebucky  I am assuming you have a lack of storage space, does a message appear to that effect?  It is always  helpful to name the model however I am aware that  this is an issue with some Tv's  (most noteably 2018 models).
I would suggest that you try a Flash Reset by following these steps:
under the Samsung logo on the TV you have a small black button about 2-3cm in from the bottom edge. With the tv turned on
1. press the button at the logo for 5-10 seconds
2. Release the button
3. press the powerbutton on the TV Remote for 5-10 seconds. Tv goes black and then restarts after a while. This is the flash reset and  many customers found it provided a solution by increasing the available storage.
7 REPLIES 7
JAMES4578
richiebucky
Trying
richiebucky
Ty
JAMES4578
@richiebucky Has the Flash Reset made a significant difference?
richiebucky
i think it an TY so much
richiebucky
great guy 👦
JAMES4578
@richiebucky  oh right thanks, good to hear 😁
