24-02-2019 04:42 PM
Sky Q remote. I was told that I can only use one remote at a time, is this true
24-02-2019 05:41 PM
@Gordon01277 wrote:Sky Q remote. I was told that I can only use one remote at a time, is this true
Hi @Gordon01277 You can only pair one Bluetooth Remote at a time, though you would be able to use an IR remote in conjunction with this (however these ones are not compatible with Voice Control) Both remotes used to be provided with the 2TB Box but it may just be the Bluetooth ones which are provided as standard now.
04-03-2019 02:52 PM
Thanks for your answer, I much appreciate it it’s a shame because we had Sky + HD before Sky Q and you could have as many remotes as you want.
GP
