Shadow across TV
(Topic created on: 24-02-2021 04:32 PM)
LewisH
Hello,
I bought this Samsung Smart 4k TV (UE55NU7100KXXU) around 2 years ago and it now has a shadow across it vertically. Does anyone have a fix? Don't expect to be buying a TV for more then 400 for it to be doing this two years later. Any help would be appreciated.
Thanks,
Lewis
3 REPLIES 3
aa68
Voyager
not a clue fella
Aklima
Big Cheese
Hi,
you will need to buy a new one or call an engineer to replace the screen.
JAMES4578
Samsung Members Star ★★
@LewisH  Yes if all picture tests are  failing this would suggest a Hardware issue.   You could contact Samsung Support for assistance.  https://www.samsung.com/uk/support/      However you may well require an engineer visit  if you wish to go down the road  of repairing set, though you may be out of Warranty.
Information on Services Centreshttps://www.samsung.com/uk/support/service-centre/  here:
