Go to solution Solved
Setting up Samsung Remote to work with Sky Q Issue
(Topic created on: 03-01-2018 08:18 PM)
happyjckjunior
TV: UE55MU6400
Software Version: 1151
Trying to set up the Samsung Univeral Remote to control Sky Q.
When going through the set up procedure, it doesn't automatically find a Sky Q box connected via HDMI (Like it does for my Apple TV where it shows the Apple TV Logo in 'Sources'),
So I select 'New Device' > Set-top Box > 'Plugged into TV Directly' > *Enters Postcode* > Selects 'Sky HD/Sky Q NW. Eng/IoM Satellite' > Select HDMI 1 (Which Sky Q is currently plugged into)
Then the TV tried to change the channel up or down which is doesn't and after 4 tries asks for a SKy Q model number which I don't know what to look for or where to find it.
I have tried all sorts of codes I can find. Our box is made by Cisco.
Looking for some help as without setting this up, I can't get my Sonos Playbar to control the TV sound.
Lordarassen
I was having the same issue. Here is how i resolved.
When it says “displays the channel playing in the small area on the screen”, make sure its a tv channel playing not the home menu of sshowing.
meaning on your sky tv remote if you press the +/- the channel should change. Then you should use the samsung tv remote to change the channel and it will change.
19 REPLIES 19
HornMonster
Model number is under the HDMI port for some reason on the back of the SkyQ box mine is ES140 but it still does not pick up the channel up or down
Padders1
Hi, I have exactly the same problem, did you ever resolve?
Thanks
Rob.
@happyjckjuniorwrote:
TV: UE55MU6400
mikebb
me too! Does not work
YNWA_Kaiser
I had same issue but it worked on 4th try.
still no idea how to control sky record/playback from the universal remote though!
JAMES4578
Samsung Members Star ★★
You may need to try a a few times but Samsung Universal Remote should be able to control SkyQ,  if you have 2 TB Box 1st generation is ES140 and 2nd generation ES240.   If you only have  1 TB Box it is ES130, personally I did not need to input these, was fine after selecting SkyQ and region.  @YNWA_Kaiser Should be able to record  via voice control, play back should be possible as long as Recordings accessible above Sky icons, however have found they disappear at times (tend to use Sky Remote for that)
18days
I have the UE65RU7400 and I’ve tried 15+ tones to set up with my sky q silver 2nd generation box / remote. I’ve chosen es130/140, em150, sky remote, sky mini, skyq, skyqsilver in fact all the sky options and I still cannot get it to work 😞
Ray6653
With the 55" (UE55H6670 ), In desteration, ended-up using the serial number of the sky remote control, supprise, supprise this worked. Would not work with the 46" though (UE46F660), this model cannot find any model numbers starting with "E".
Ray6653
Seems tpo me the biggest problem is the lack of response from Sky or Samaung in responding to these queries?
scully145
This should sort all smart remote issues
hdmi needs to be of high quality
not more than 2mtr long
just plug & unplugg in till it searches for devices
run through set up
will not change channels when prompted
channel up channel down
but still select Yes
it will work
