Screen cleaner
(Topic created on: 22-02-2021 04:51 PM)
Simo37
Anyone got any recommendation for which cleaning solution?
1 REPLY 1
antikythera
Black Belt
yes, none. use a dry microfiber cloth or if you must make that cloth slightly damp to shift fingerprint marks or grease. additionally do not press hard while cleaning the screen or you can bruise it which leaves a permanent white area when the TV is on
