Samsung TV QE49Q70RATXZT won't change channel
(Topic created on: 13-10-2019 06:46 PM)
HappyHippo1
Hello,
I have a strange problem... While scrolling trough the channels and after I reach a certain channel I cannot change the channel with the "ch+ of ch-" buttons on the remote no way... I have to go use the channel list or channel guide...
How is that possible???
Thanks for your help in advance!
4 REPLIES 4
CarlH
Hi @HappyHippo1. Can you tell me which software version you're currently running?
HappyHippo1
It should be the latest...
T-MSMDEUC-1315.4,B1912200/050504,BT-S
CarlH
Thanks for the info, @HappyHippo1. I've just taken a look and there is a new version available (1318.0). If you're unable to download it directly from the TV, it can be found here.
This requires access to a computer and USB stick. If you're unable to do that, let me know and I can arrange a USB stick to be sent out to you with the update on.
HappyHippo1
So I did the update... And it still doesn't work 😞
