23-02-2024 03:16 PM
Hi. Can anyone tell me why the firmware update option on my S95C isn’t available in my settings, it’s blanked out and saying not available. I am connected to the internet ?
Solved! Go to Solution.
23-02-2024 03:33 PM
Hi @63johnw Usually an issue when the source is not set to TV. possibly switch of at mains for a minute, switch on and ensure you are connected to the Internet. Go to Settings-Support-Software Update and if still greyed out ensure the source is set to live Tv and not on an app.
Alternatively you can update via a USB download https://www.samsung.com/levant/support/tv-audio-video/how-to-update-the-samsung-tvs-firmware-using-a...
Firmware for S95C is here https://www.samsung.com/uk/support/model/QE55S95CATXXU/#downloads
23-02-2024 03:33 PM
23-02-2024 03:37 PM
Thanks @JAMES4578 i was looking when using an app, looked on live TV and option is then available. Much appreciated.
23-02-2024 03:42 PM
@63johnw No problem, glad you are sorted
