Samsung QLED QE65Q85RATXXC LAN not working proberly
(Topic created on: 23-01-2020 07:45 PM)
lt03
Pioneer
I bought a Samsung QLED QE65Q85RATXXC just before christmas.
I connected it to the internet with a LAN cabel, but every 1 or 2 days i get the message "network cabel is connected" on my screen.
So i bought a new LAN cabel,  changed ports on the router, reset network settings on TV and rebooted everything, but the same.
It is was like 4 days old when it did it the first time. Should i return it to the seller as faulty? Hope you guys can give me some advice.
Modelkode: QE65Q85RATXXC
Softwareversion:T-MSMDEUC - 1335.0, B6970101/070204, BT - S (Searched for new updates, this is still the newest)
8 REPLIES 8
ChrisM
SuperStar
Hi @lt03
Let's see if we can get this sorted out for you. We're not able to access the link you provided. Are you able to add the pic directly on here for us?
lt03
Pioneer
I have uploaded the picture in the original message.
ChrisM
SuperStar
Apologies, @lt03. You've come through to the Community team in the UK here. Could you give us a direct translation of the message please?
lt03
Pioneer
I think this one is mine. It is a English site.
The message in the top right corner in the picture is the message from the TV.
It reads:
Netværksindstillinger = Network settings.
Netværkskabel tilsluttet = Network cabel connected (LAN cabel connected)
ChrisM
SuperStar
Does the message stay on screen until you select OK and does it then disappear?
lt03
Pioneer
The message disappears after about 1 min without pressing OK. If you press OK it disappears immediately.
lt03
Pioneer
Have you got a idea of what is causing it?
lt03
Pioneer
The problem of unstable LAN continues
I have contacted the vendor, who promtly sent me to samsung.
I am now doing many test with samesung support. The process takes a long time, especially when the mistake is every 1 - 4 days, change one kabel - wait - chang................... 🙂
