07-01-2023 12:04 PM
Samsung TV purchased in October 2022 - worked perfectly till yesterday when all aerial/terrestrial channels have been lost.
Have used Online Chat and he accessed the TV via Remote Management - couldn't resolve so awaiting a text message from Samsung once this has been escalated - no idea when this will be sorted.
Aerial cable has been unplugged and re-plugged.
TV has been reset (so losing all Apps and having to log back into them again)
Samsung TV Plus has been disabled.
There are no faults with the aerial cable or transmitters here.
Online helper tried to go into Broadcasting/AutoScan and could see that there's no option to do an autoscan or manual scan so we are completely stuck.
Clearly alot of people on here with the same issue - has anyone had it resolved or do we just need to return this TV and get one that isn't Samsung!!
thanks in advance.
L
07-01-2023 12:21 PM
07-01-2023 12:26 PM
Thank you. Think you might be right as no other real explanation why it has suddenly stopped working.
Just plugged a spare freeview box in to prove it's not an issue with cabling or transmission. Fingers crossed we hear from Samsung soon.
08-01-2023 04:59 PM
So had to chase a response from Samsung today. Another 90 minutes on online chat,.this time a full factory reset done by them and the problem is still there. No aerial/terrestrial channels and no ability to auto scan. Now got to wait 24 to 48 hours fro a phone call from them as it's a very unusual case apparently.
Meanwhile we plugged in an old freeview box and can access all channels. This together will all other troubleshooting surely confirms the TV is faulty?!?
14-01-2023 06:41 PM
18-01-2023 12:03 AM
had the same issue, Samsung support weren’t able to resolve. I resolved it by unplugging tv from power for 2-3 minutes, reconnect power lead and rerun reset/setup then all good! Terrestrial tv now back
28-01-2023 08:32 PM
Did this really work? Anybody else used this method?
12-10-2023 09:45 PM
12-10-2023 10:19 PM
27-10-2024 01:42 AM
Hello,
I have the same problem also, any solution yet?
Thank you
