Samsung QE50Q60T
(Topic created on: 24-11-2020 09:03 AM)
Astra39
I’m interested in buying this TV: Samsung QE50Q60T
However the TV will need to stand on a unit that is narrower than the width of the screen. So I’m trying to establish the distance between the two legs that the TV stands on.
Is there any way of finding that out please?
Thanks in anticipation.
6 REPLIES 6
DUMITRU79
Troubleshooter
there you go
DUMITRU79
Troubleshooter
and this
DUMITRU79
Troubleshooter
But , if you have a " space " problem, then you might wanna consider wall mounting ?
Astra39
Thanks for your suggestions.
Wall mounting is not straightforward because of the intended location.
The published spec doesn’t really help because it’s the width between the legs that is critical dimension.
DUMITRU79
Troubleshooter
well then...as the manufacturer never mentions it , i would suggest you find nearest store that sells it and di the measuring yourself , as i see nowhere those measurements 🙂
Astra39
Any other suggestions Samsung community?
