SAMSUNG Q80T ST.2084 Gamma Issue
(Topic created on: 24-08-2020 10:08 AM)
bomibomi93
Hi. My Q80T has the ST.2084 and HLG options greyed out. The only gamma options to choose are BT.1886 and 2.2 how do I choose ST.2084 ? Thanks a lot.
5 REPLIES 5
smp79
ST.2084/HLG are for HDR content.
Danboy76
Even playing HDR games on the xbox one x they are greyed out..
KindOldRaven
Pioneer
Then your TV isn't running in HDR mode. Double check if your Xbox actually has HDR enabled, especially if you just got this TV.
Martin
Hey, i was having the same problem for a while.
Go to video output settings on your Console, then u choose 2160-P - YUV420
then I start the game u want to play with 4k. Then u go to your settings in the tv you are using, and then u will see at.2084 and hlg is available to use. Hope this helps. I was going crazy until I found out.
MrneoRobot30
thank you very much man, I suffered for half a year and you helped me a lot !!!!! many thanks for the help with the setup! i love you!!!=) hello from Ukraine!
