Samsung Odyssey G7 DP issue
(Topic created on: 06-03-2023 05:22 PM)
Members_XD2roIs
Purchased this monitor a few months ago, and today run into an issue!
Turned my  PC on, and the monitor is completely unresponsive, power button is lit solid. but screen is black.
Reset my PC, unplugged the monitor completely and it came on, but now when I have the screen set to DP 1.4 the resolution is stretched so I can  only actually see the top left quatre of the screen, tried messing with PC settings to fix this issue, no joy.
Playing with the monitor settings, the only thing that makes the screen good again, is setting DP to v1.2
Upon launching PIP mode and turning it off again, I am back to the original quality at DP1.4 (seemingly fixing the fault)
I'm using the original power/DP cable.
Is this a common fault? is there any suggestions as to why this might be happening?
3 REPLIES 3
Egg1
Voyager
I deeply regret my choice of G7 Odyssey, mine is disappointing too
fraz15
i have the same issue but could not solve it using your method.. can u elaborate how you solved it?
