Samsung 32inch TV T5300, what is the distance between the feet, will it fit on 65cm unit
(Topic created on: 05-11-2020 11:52 AM)
Members_vfypMen
Will T5300 TV fit on  65cm unit
1 REPLY 1
AndrewL
@Members_vfypMen: I've had a look into this for you, and can see that the set size with the stand attached is 737.4 x 465.4 x 150.5 mm (WxHxD). As the width is 73.74cm, it looks like it is just a little bit too large for your home unit. Apologies for any inconvenience this may cause you.
