S95C screen saver Continue Watching option doesn't respond
(Topic created on: 27-05-2024 03:03 PM)
ravetroll
I have a S95C which I use for a computer monitor.  Occasionaly the screen saver turns on and asks me if I want to 'Continue Watching'  .  When I first got the TV i just pressed the middle round button on the remote and it continued.  That button now does not let me click the option to continue watching while the countdown starts to auto-shutdown.  To keep the picture on screen, I must press the home button on the remote which then shows my menu with the HDMI screen in the little inset.  Then clicking the middle round button brings back my screen.  I suspect this is caused by a software upgrade on the tv as the button does work, just not in the way I would expect.  Has anyone else experienced this?
6 REPLIES 6
Obsydian
Samsung Members Star ★
Wow, hard-core a S95C for gaming 👏
It's usually the auto off, not sure you can turn it off as mine is set off but still gives a saver warning.
2 Decades Samsung Ownership, Follow me on Instagram Obsydian_SMS
DAILY: S25 Edge, ZFold6, Watch Ultra, Fit3, CL Ace 2, BT-W6, 20,000 Power bank, Smart Tags
FAMILY: ZFlip5, ZFlip6, Watch6 Classic, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFlip4, ZFlip3, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
ravetroll
Hehe, yes it is for gaming and is amazing, but also for work, huge spreadsheets and comparing documents side by side is a massive productivity boost.
I don't think the auto-off can be turned off, but I am not so concerned by its appearance from time to time, it is more that I cannot easily dismiss it with the remote like I used to be able to.  It seems as if a software update has removed the ability to press the "Continue Watching" button with the remote which is annoying and clearly not how it is supposed to work.  How can I get Samsung to look into this?
Theev90
Having the same issue with my S90C. Not able to click the "continue watching" button on the prompt that appears.
vitorvieira
I have the same issue.
When is Samsung going to provide a fix for this??
Members_21VwDCP
Same issue on QN90C
vitorvieira
Hi all,
I have a Samsung soundbar and I found the "Ok" button (central round button, like the TV's) on the soundbar's remote  will close the message.
Very annoying to have to keep the second remote around just for this purpose.
Hope this helps someone else.
Best regards,
Vitor
