Ring Doorbell and cameras Video on Samsung Crystal UHD UE43TU7000
(Topic created on: 29-06-2021 02:52 PM)
Doverrog
Hello. We have 3 Samsung Tvs. The main set is a UE43TU7000 Crystal UHD.
We have a Ring doorbell (series 3) and 2 Ring cameras.
Is it possible to get the Ring video to display on the tv?
I've set up the "Smart Things" app but I can't find a Ring app.
Can anyone help?
doverrog
6 REPLIES 6
Doverrog
Thanks. I've got the SmartThings app on my phone but on the tv although the Smarthings does work some controls and is connected, it's not showing Ring notifications.
doverrog
xSteveuk
Mastermind
AndrewL
@Doverrog: Please follow the link below to find a step by step video guide on our official YouTube channel
How to connect a Ring Doorbell with your Samsung TV - YouTube
Doverrog
Hi AndrewL. Thanks for the link. I've worked through it and all is fine until it shows the TV screen and says login to SmartThings.
SmartThings doesn't appear on my TV. I've done the App search and it doesn't come up. I've tried going via the web on the TV and again no luck. The web search finds the SmartThings app and says it's installed.
The app is fine on my phone and shows both the Ring doorbell and the TV.
I have a Samsung UE43TU7000 Crystal UHD which was bought in June last year.
The auto update for software is switched on.
Would a manual software update on the TV deliver the app, or are we waiting on Samsung to download it to the TV?
doverrog
Doverrog
Hello Andrew. Have you found anything?
I would like to know if "SmartThings" App should be on my UE43TU7000 Crystal UHD?
The video show it but it doesn't come up on my TV screen.
doverrog
