09-08-2022 09:57 AM in
TVHaving now 'upgraded' from the 2020 model Q950 to the 2022 model QN900B, I'm finding the universal remote's ability to control Sky Q is a *massive* step backward. You used to be able to simply hit the Home button, then arrow up to access the Sky box menu/guide/recordings and frequently used channels. This is seemingly gone completely, as the Home button now brings up the full screen Samsung Home Screen with no obvious shortcuts to anything useful.
The only alternative appears to be hitting the Settings/123/RGB button, then navigating up/down to the 'control' section (below the numbers section), then navigating left/right to find the right button.
Am I missing something somewhere, or is this supposed to be an improvement?
09-08-2022 02:42 PM in
TV@twuk I do not have one of the latest models to check, can anyone else confirm this issue? I take it it makes no difference if you set the Universal Remote again.
One Ui 5.0,Android 13 .
09-08-2022 03:13 PM in
TVI've tried that (twice) just to make sure the installers hadn't done something stupid. I'm afraid it made no difference.
The only thing I would add is that when doing this on the 'old' model I recall dancing through various 'Sky' devices until I found the right one, but with this model the wizard seemed to find the Sky device immediately and the settings offered worked the first time. I also tried then deleting the device, adding it back, and manually stepping through other options. Sadly it made no difference.
I suspect Samsung thinks this new 'home' screen is an improvement, probably because it presents what they want to show you, but it drops the very useful functionality that allowed one to interact with the Sky box. Given the likely number of UK users that rely on Sky for their TV, this is likely to become a bigger problem. I've no idea when this change came about, so not clear on how many Samsung devices will be in the wild at this point.
09-08-2022 03:57 PM - last edited 02-10-2022 01:19 AM ) in
TVThanks for confirming does seem to be an issue that can only be sorted in a roundabout way. Yes on my model when I checked presented with a few Sky options plus Virgin and BT amongst others.
09-08-2022 06:45 PM in
TV09-08-2022 07:04 PM in
TVYes, true, however you can't access Sky guide or recordings from there. Only way appears to be the 'number' button and then navigating down to the cable box menu button.
09-08-2022 07:42 PM in
TV09-08-2022 07:49 PM in
TVYep, that’s what I’ve suggested above is the only workaround. Far more painful than the old way.
09-08-2022 08:04 PM - last edited 10-08-2022 09:17 AM ) in
TV
