QE65QN93D Freesat
(Topic created on: 20-12-2024 11:11 PM)
carsey
Hi all
I have the above TV and just bought a house which comes with a existing Sky dish on the wall and the wiring.
Is it possible to connect the cables to the back of the TV in order to get free-sat TV?
Thanks
Chris
4 REPLIES 4
Lippy
Voyager
Hi Chris
Have you tried going to freesat website? You might find the info there.
I know that if you have a freesat box you just use the existing sky dish and cables but I don't know what you do if you have freesat on your TV.
Moiramon
Samsung Members Star ★
A sky dish will pick up Freesat. astra 2 satalite east if it asks in the setup. Done it myself.
KP_76
Voyager
Definitely possible with a Sky HD Dish connectio. I have the QN90D and my Sky Dish coaxial cable is connected to the main LNB socket on the TV. You will then need to re-tune your channels, ensuing you select FreeSat for the channel search.
Please note that with the Sky Q wiring, it may require a different connection to the dish. But you can always buy a FreeSat box if it gets to difficult.
carsey
Tried to connect the cable,  seem to be able to only get one wire connected to the Main port on the TB (sub won’t screw in) but the TV doesn’t pick it up and allow teatime the TV.
