Q90t disconnecting from wifi
(Topic created on: 16-06-2021 02:45 PM)
Cluyando
Just bought the 2020 Q90t and so far every day it disconnects from my network overnight. It’s fine the whole day turning the tv off and on. This happens overnight and each morning I have to reset the network setting and reconnect to the network including re-entering the wifi password. What is causing this and what is the permanent fix?
2 REPLIES 2
xSteveuk
Mastermind
RESTART YOUR SAMSUNG TV
This is the easiest possible fix for the internet connection problem on your Samsung TV
It should work if your TV is having a connectivity problem
abby7777
i will never buy another samsung TV. The wifi password is most annoying. reason enough to never buy another one
