Q60t USB mkv subtitles show first line then disappear
(Topic created on: 20-12-2020 11:55 AM)
Morke
Hi all.
I'm a proud new owner of a Q60t and I'm enjoying it a lot.
However I'm trying to play a mkv movie with vobsub subtitles from an external drive and i can't get the subtitles to keep playing.
When I select the subtitles for the first time or a exit the playback and i re-enter it, the first line of the subtitles of that part of the movie displays correctly.
And then the disappear and no more subtitles are shown. And after that, the subtitles menu gets locked and the sync, re sync and size options are locked until I exit the movie and re play it.
Any ideas on what's going on?
1 REPLY 1
vaIIy
Im having the exact same issue. Did you find a solution?
