4 weeks ago in
TV4 weeks ago in
TVHi @LC8319 Does your Tv have the latest firmware, you have not named the model but can check on Samsung support https://www.samsung.com/uk/support/
However if there is a lack of storage space I would suggest a Flash Reset:
Under the Samsung logo on the TV you have a small black button about 2-3cm in from the bottom edge. With the tv turned on
1. press the button at the logo for 5-10 seconds
2. Release the button
3. press the powerbutton on the TV Remote for 5-10 seconds. Tv goes black and then restarts after a while. This is the flash reset and many customers found it provided a solution by increasing the available storage.
One Ui 5.0,Android 13 .
3 weeks ago in
TV3 weeks ago in
TVI do not work for Samsung or make Samsung Products but provide independent advice and valuable contributions.
3 weeks ago - last edited 3 weeks ago ) in
TV3 weeks ago - last edited 3 weeks ago ) in
