Please help
(Topic created on: 27-12-2021 01:08 PM)
Houston2
 this bar has been haunting me I messed around in my settings and backed out of the menu and it keeps popping up for a few seconds covering what ever is under it, I’ve talked to customer support and they kept telling me to factory reset my tv with the remote but the remote doesn’t work, this hasn’t happened in the 2 years I’ve had this tv and the bar goes away when I open the menu or press any of the buttons on the tv, if someone could help troubleshoot I would greatly appreciate it.
2 REPLIES 2
N1NJATH3ORY
Voyager
Turn it off from the power socket then turn back on use remote to navigate to reset menu and proceed to hard reset once done follow on screen instructions to setup your smart TV
BlazingAura
If anyone sees this and has this problem,  the solution is to press the volume button (+ or -) and while the bar is still on the screen, hold the menu button for 5 seconds. I did this with the TV itself and not the remote.
