Go to solution Solved
Picture clarity setting grayed out on external HDMI source
(Topic created on: 24-10-2023 05:12 PM)
s4msb
Just got the S93C and wanted to use the frame interpolation on a Blu-ray that is played on my PC. So I connected it with an HDMI cable but the "Picture Clarity" menu is grayed when I select my pc as source. How do I fix this?
Can't believe that I couldn't find a thread about this...
Phoenixia
Because certain options in there aren't generally suitable for general use and can issues or annoyances, for example the input lag that Picture Clarity brings. So you basically go to your home screen, by pressing the House on your remote control. Press Left and you'll see Menu with 3 lines, press down and it'll select it and you'll see Settimgs, Connected Devices and Multiview. Click Connected Devices. Press right twice and you'll see the sources on the bottom, with SmartThings being thr first icon followed by TV etc.on the left down to Connected devices or Smartthings. Select your pc icon, click edit, and change the icon/type to something like BluRay player from the list dropdown. Now your TV will treat it as a media device and change the available settings presented that you can adjust. You should now be able to use Picture Clarity Settings. Don't turn Game Mode on during this, or it will revert to pc again / change the device icon in the menu I showed you earlier into a Games Console. What you CAN do is go to the settings, Connection > External Device Manager > Input Signal Plus and enable it for basically all the HDMI ports. If you don't usually use this with your PC or the S93 somehow didn't, once you change your "Bluray" back into PC, go to the all Settings menu, down to Connection and click it, click External Device Manager, Input Signal Plus and make sure it's on for your pc. You can also go back, and underneath you'll see Game Mode. Turn it on when you're usually using your PC or basically anything other than Blu Ray stuff. Turn it on and you'll also see Surround Sound turn on (blue checkbox). You can adjust a few more things in this menu to make the most of it as a monitor, experiment around and you'll find you'll end up with the perfect settings and no input lag.
Just wanted to throw this out there for you all, enjoy!
4 REPLIES 4
Phoenixia
s4msb
Wow thanks! This is actually a pretty clever solution from Samsung to not annoy gamers with interpolation.
Phoenixia
Indeed it is! I suspect it's because there's always that slight off chance of the automatic detection being wrong so they put options in there as workarounds even though they're hidden or obscure to find except by chance which is how I discovered it, I too had a similar issue and was trying to find a workaround which I'm glad was able to help you too :smiling-face:
jcg7
Hi, I am also experiencing this issue. I followed your methods and was able to get a fix, thanks lots! However, I do notice that
1. If I choose to enable Input Signal Plus (for the high frame rate), then I cannot use picture clarity settings.
2. If I change the icon to a "Blu-ray player" or a "home theatre", then I can use picture clarity settings, but my Input Signal Plus will automatically be turned off.
Put simply, I cannot use Input Signal Plus and Picture Clarity Settings at the same time.
That is what you experienced as well right?
