One Connect Box USB ethernet
(Topic created on: 21-08-2021 08:27 AM)
Buyingpan
Has anyone used the USB ports on the one connect box to speed up the ethernet connection. I know all tv are 100mbit rj45, but you can overcome this by connecting rj45 into a connector that fits usb you can reach speeds over 300mb.
Is it the same with the connect box?
1 REPLY 1
trojanac
I tried but the connector on the box is 2.0 but on the rj45 its 3.0 so you can't get that speed.
