NU8000 IPTV not working
(Topic created on: 08-05-2019 05:13 PM)
Nugu
Hello, does anyone else having issues after the new firmware(.1251) with the IPTV apps?
Everytime I try to open a channel it returns "stream error" and sometimes stuck on connecting.
Tried a fresh install on apps but same thing happened. Also I reset the TV.
The m3u is fully playable on other devices.
So i suppose that something is wrong on the new firmware.
Is there a way to roll back the frimware manually, via Usb?
And if it is possible, where I can find an older firmware to download? On the official site it has only the new one(.1251).
Thanks..
Andy!
5 REPLIES 5
paul1277
Black Belt
Thanks..
Andy!
Don't think you can go backwards with firmware.
Nugu
Thanks for the quick response..
uykusuzfil
Hi,
Did you find a new solution for this app?
Thank you,,
Nugu
Hello..
Nope, still no solution. But I have to say that the problem is not the same as the first days of the new firmware.
The only thing I ve done is to change the dns settings to Cloudflare dns server on my router. (1.1.1.1)
I really dont know if this is something, but now my IPTV seems to run smoother on my TV.
Maybe my IPTV provider was faulty too. Dont know. Try some tests on other IPTVs and check by yourself.
Andy.
adil_turkey
Hello,
Could you try to remove dns addresses from your modem settings.
