Nu7120 tv
(Topic created on: 02-04-2019 01:03 PM)
Jonnyboy1234
How can I use my wi fi headphones.There is no 3.5mm jack.I also can't seem to connect bluetooth headphones.Aaaaagggggghhhhhh I need hesdphones lol.x
3 REPLIES 3
AndrewL
@Jonnyboy1234: For Bluetooth headsets you can try the following:
- Enable Bluetooth on the headphones and go to Settings > Sound > Sound Output > Bluetooth Speaker List and select your headphones from the list of available devices. If the TV fails to find them, place the device closer to the TV, and then select Refresh
Please be aware that you can't use Bluetooth devices and the Wi-Fi Speaker Surround Setup feature simultaneously.
Jonnyboy1234
Andrew it doesn't come up Bluetooth or speakers.And it doesn't seem to pick up anything.I have wi fi headphones eith a 3.5mm jack but no port on tv,how do I connect them without it.
JAMES4578
Samsung Members Star ★★
@Jonnyboy1234, the NU7120 does not seem to have bluetooth built in  https://www.samsung.com/uk/tvs/ue40nu7120kxxu-uhd-4k-smart-tv-nu7100-series-7-ukfrdeites/UE40NU7120K...
An option is to use a Bluetooth Transmitter, if no headphone jack though you would need one with optical connection.  https://www.lifewire.com/add-bluetooth-adapter-to-tv-4174442
An example of Uk one here Bluetooth-Transmitter-Receiver
