No threads for screws on tv mount holes UE32T4300AKXXU 32"
(Topic created on: 31-10-2020 08:55 PM)
Angmul
Hi I just bought a 32” UE32T4300AKXXU tv and am having major difficulty mounting it to the wall. The vesta spacing is only 100x100 which makes it incompatible with my mount I bought. Also no screws fit, as far as I can see there is no thread for the ems crews to attach to. It seems to have a Hexagonal at the base of the holes. Has anyone successfully mounted this model tv to the wall? Are there particular fittings that I would need..?
3 REPLIES 3
Kimbals69
Did you find a resolution to your issue, as I have exactly the same problem.
Apocalyptix
Just had same problem with my daughters new tv. What a rubbish TV having no thread. I've fixed the mount to the wall already. What a waste of time and money. I'll never buy another Samsung TV.
robmorgan
I thought this applied to me because my Samsung TV seemed to have just two smooth holes with an unusual screw thing right at the back.
I thought I was missing some pieces. Actually, it turned out there is a screw thread, it's just it's towards the back, behind the smooth section- you can't see it, but you can feel it if you stick something inside. I got a long bolt of the right side and it did screw in fine.
