Network Cable Disconnected/Connect message
(Topic created on: 10-02-2023 03:44 PM)
ScouseNotEnglish
Navigator
Last post i could find relating to this was old and without a resolution.
My TV is a UE49MU7000.  cURRENT vERSION: 1310. NO NEW UPDATES AVAILABLE.
Has there been any resolution to this? I am connected (Via eithernet) to a fairly new LINKSYS IP6 Mesh system, with no other issues. Usually between 10-20 times a day i get "Network Cable disconnected" "Network cable connected" messages... rather annoying.... Has Samsung issues even an aknowlegement of the problem, let alone an update/fix, or is that too much to ask for?
Galaxy Book4 Pro | S24Ultra | GalaxyTabS | Galaxy Watch |
Tags (1)
5 REPLIES 5
Obsydian
Samsung Members Star ★★
I get this sometimes check your cable is not pulled in any direction or faulty.
Samsung Owner since 2006 | Community Member since 2012 | Instagram: Obsydian_SMS
ScouseNotEnglish
Navigator
Turn it off, turn it on again? Plug it in again?, you kidding me? I'm an IT Infrastructure specialist of 20+yrs.... 🙄
Krayzierone
Im experiencing similar symptoms when casing it just cuts off try downloding samsung caster and see how much your internet drops off its not your internet its the tv receiving your internet i had my router TP-LINK firmware updated at no change. I also reset the TV.
MDEV2
I too have the same issue. At this point it looks like either the hardware in the TV is absolute junk or there’s a software bug. I get the disconnect/connected messages randomly through the day. Sometimes when powering on from standby it just forgets it’s connected to the internet altogether.
Very annoying.
KennyBVA
I'm having the exact same issue. It started after replacing my Asus router with a Linksys Velop. Only happening on the Samsung UN70 TV with ethernet connection. It worked fine on the Asus router. 30 other devices both ethernet and WiFi working without issue.
Anyone ever find a solution?
