Go to solution Solved
Where is S95B MICROPHONE ?
(Topic created on: 11-02-2023 07:04 AM)
redtees
TV
Setting up a new 65" S95B.  I can't for the life of me find the microphone on/off switch.  I've looked closely all along the bottom of the TV.   It's not behind the Samsung tag.
(I did find that you can turn the TV on by pressing by the remote eye. LOL)
Thank you.
2 Solutions
Obsydian
Big Cheese
TV
Don't believe there is, for my 95A it is the remote, for Bixby, Alexa and even Ring camera 2 way talk.
Regards, Obsydian
DAILY DEVICES
ZFold4 [Mobile], Pro5 [Watch], S8 Ultra [Tablet], Book2 Pro i5 5G [Laptop], Buds Pro2 [Buds] M70A 32/43" [Monitor], Smart Tags+, iPad Mini 5 and iPad Pro 12.9 GEN2 [Tablets], Dell Inspiron G5 Laptop
HOUSEHOLD DEVICES
ZFlip3 and ZFlip4 [Mobile], Watch5 40mm and 46mm [Watch], S7+ and S6 Lite [Tablet], QN95A [TV], Q900A [Soundbar], MC28M6075 and MC32K7055 [Microwave], Jet 75 Complete (Vaccum), Samsung Level [Speaker], Buds Pro [Buds], iPhone 12, iPad Air 2, Air tags
Bluesmooth
TV
Hello Journeyman, I have the same S95b and I have the microphone  button. It's  not behind the samesung tag. It's about 12 inch to the left of the samsung  tag. It's a little hole where you can stick  your  finger and slide the button  to the left. From there can go into settings  and turn the voice  on. Once  you do that  put the voice on Bixby  and then you can say Hi  Bixby  without  the remote  control  and Bixby  will do or answer  the question  you ask it. I put  a picture  of the samsung  tag. IAgain if you go about 12 inch to the left of that tag it's  a small hole where you put your finger and switch  the biut to the left.
13 REPLIES 13
Obsydian
Big Cheese
TV
Regards, Obsydian
DAILY DEVICES
HOUSEHOLD DEVICES
redtees
TV
Thank you.  I've come to the same conclusion. I thought I read somewhere along the line that you could turn the mic on or off.
I've set the TV to Google Assistant and linked with my phone but nothing happens when I try to talk to the TV.  I must be doing something wrong somewhere....thanks again.
Obsydian
Big Cheese
TV
No problem if its any conciliation I spent quite awhile reading if it had a year ago, good we can save each other sometime 🙂
Regards, Obsydian
DAILY DEVICES
HOUSEHOLD DEVICES
Ginga_p
Helping Hand
TV
On the qe95b its in the bottom right corner but its really well recessed so you have to run your finger nail over it to find the switch
G G
redtees
TV
Thanks Ginga, but all I have there is the Samsung logo held on by a screw underneath.
Members_rCLK5RB
TV
There is no microphne attached to the TV.  The only microphone for the S95B is on the universal remote.  You have to press the middle button above the direction circle and hold it down all the time you talk into the very top of the remote where the microphone is.
It's actullay quite a smart move, as you don't have to preface everything with "Hey Google" or "Alexa"  so your voice commands to the TV won't be caught by your nest or speaker.
redtees
TV
Thank you CLK.  It never dawned on me that the little hole WAS the mic.  I'm just tech savvy enough to be dangerous.  My problem was that even though I was sure that I had GA set up correctly, all my yelling and swearing at the TV wouldn't get a response.  After a couple of hours of troubleshooting I finally read something about re-pairing the remote.  I did that and voila!, GA responded!!  For some reason my brand new remote with my brand new TV was just a bit off.😁
Bluesmooth
TV
Bluesmooth
TV
