15-11-2020 02:59 PM
09-12-2020 11:59 AM
I have exact same model fridge updated fully, I am not able to connect to my 800T 8K Samsung TV. It works fine with Note 20+ Ultra. Just not Samsung TB cannot mirror it.
09-12-2020 12:00 PM
This seems to be 2020 TVs not compatible. Can anyone provw this otherwise.
13-07-2021 12:58 PM
I have the same issue with a Q5t TV
13-07-2021 02:13 PM - last edited 13-07-2021 02:14 PM
Are you able to locate both the TV and the Family Hub on the SmartThings app? If so, it should work and connect.
First up, check that your Hub is up to date:
1. Open the Family Hub settings
2. Choose About device
3. Choose UPDATE
Then check the Connection on your TV:
1. Open the settings on your TV
2. Go to General
3. Choose External Device Manager
4. Choose Device Connection Manager
5. Turn Access Notification to Always on
6. Choose Device List
7. Make sure that your refrigerator is set to Allowed
Let us know how you get on.
Welcome to the Community!
13-07-2021 03:53 PM
I checked the fridge; FH was up to date. I changed Notifications to always on, on the tv but the fridge doesn't show up under devices, only the phone (which indicates that it's allowed). The fridge always shows under SmartThings on the fridge, including listing the programme that's playing.
18-07-2021 09:37 AM
I don't know if the OP's issue has been resolved but the TV still doesn't show up under devices on the fridge, so I cannot cast a programme to it. In SmartThings, I can switch the TV on and off, and see what channel is playing. I installed SmartThings on the TV and it can see the fridge.
09-06-2024 09:30 PM
Hello,
RF32CG5900SR
I have an older model tv model and it works with the Samsung hub RF32CG5900SR. My 2016 tv allows me to mirror on the refrigerator. However, my 2021 and 2022 models do not work. Below are the models that are compatible:
2021: (A models)
All 8K QLEDs (Neo)
4K QLEDs: Q70A, Q80A, and Q90A
The Frame (LS03A) (43 inch and higher)
The Terrace (LST9TA)
2020: (T models)
All 8K QLEDs
4K QLEDs Q70T or above
The Frame (LS03T) (43 inch and higher)
The Serif (LS01T)
The Sero (LS05T)
2019: (R models)
All 8K QLEDs
4K QLEDs Q60R series or above
The Frame (LS03R)
The Serif (LS01R)
2018: (N models)
QLEDs Q6FN or above
UHDs NU7400 or above
The Frame (LS03N)
2017: (M models)
QLEDs Q6FM or above
UHDs MU6400 or above
The Frame (LS003)
2015-2016: (J/K models)
JU6400/KU6400 series or above
