05-01-2025 06:22 PM
I have just convinced my partner that we need a new TV and have purchased a Q80D. While I am generally happy with it, one thing I can't seem to make it do is show my NAS as a source. Our previous TV (also a Samsung) had no issues.with doing this. As long as the NAS was on the same network, which it is, the old TV would simply have it listed as a source. The new TV won't do this.
Does anyone know how to get it to show as a source?
05-01-2025 06:38 PM
05-01-2025 07:53 PM
08-01-2025 12:34 AM
Older televisions supported DLNA technology, allowing them to connect to a network and access files stored on servers using the appropriate protocols. However, modern consumer TVs no longer support DLNA, as it has been replaced by more advanced technologies like Chromecast and Apple AirPlay.
In the past, people often downloaded videos to their computers and streamed them to their TVs over a local network. Today, streaming platforms have largely taken over, with most users opting to watch content online directly.
If you still prefer to watch offline content, simply transfer the files you need onto a USB drive and connect it to your TV. Unless you’re managing a library of 100 terabytes of video, this should work perfectly.
26-02-2025 08:13 PM
Hi, my Qe55QN95 had the same problem, if you change the TV name and remove spaces and special characters all will be fine, best of luck
Regards Geoff
01-03-2025 05:57 PM
Did you find a solution?, as I have just purchased the same model. My laptop connects but my NAS won't which it did on my previous Samsung.
