Nanomid iptv samstv tizen!!! Not found store!!!
(Thema erstellt am: 10-01-2025 06:58 PM)
662 Anzeigen
Kflamur
hello I want to install Nanomid player iptv on samsung tv tizen, but I can't find it in the Store! Is there any way to install as APK file and how can do it!!!
Thank you!
13 Antworten
Anonymous User
Nicht anwendbar
In order to use Nanomid player on your Samsung Smart TV, you need to connect it to the Internet and download the app from your TV's store.
If you can't find the app, your model is probably not among those enabled for the service.
https://nanomid.com/en/player/tech-specs
Kflamur
I cant to find ...
Anonymous User
Nicht anwendbar
Then your model is probably not among those enabled for the service.
Kflamur
Can I apk file install?
Anonymous User
Nicht anwendbar
Pom-Fritz
Pathfinder
You ask for "apk-file". Apk-Files can only installed on devices using Android-OS. Samsung use the Tizen-OS.
Kflamur
true, but samsung tv also has Develop mode for APK files. normally it should work as Apk file .. if not then why does it have DEVELOP MODE option
Anonymous User
Nicht anwendbar
Englisch:
APKs are developed to work on Android devices as they are written in Java. For this very reason, they cannot be run on a Samsung Smart TV as they are powered by Tizen OS. Tizen and Android are both based on Linux, but there are no further similarities between the two. Tizen was developed in C++, whereas Android was developed in Java. Naturally, APK files, that we now know are JAVA-based, would not function on Samsung TVs, and even if you managed to get one on a Samsung Smart TV, your TV device wouldn't be able to identify the APK file or begin its installation. In addition, Samsung TV has security safeguards that prevent anyone from installing APKs from untrusted sources in order to protect the system.
Deutsch:
APKs werden für die Verwendung auf Android-Geräten entwickelt, da sie in Java geschrieben sind. Aus genau diesem Grund können sie nicht auf einem Samsung Smart TV ausgeführt werden, da diese auf dem Tizen-Betriebssystem basieren. Tizen und Android basieren beide auf Linux, haben aber keine weiteren Ähnlichkeiten zwischen den beiden. Tizen wurde in C++ entwickelt, während Android in Java entwickelt wurde. Natürlich würden APK-Dateien, von denen wir jetzt wissen, dass sie JAVA-basiert sind, auf Samsung-Fernsehern nicht funktionieren, und selbst wenn Sie eine auf einem Samsung Smart TV installieren könnten, könnte Ihr Fernsehgerät die APK-Datei nicht identifizieren oder mit der Installation beginnen. Darüber hinaus verfügt Samsung TV über Sicherheitsvorkehrungen, die verhindern, dass jemand APKs aus nicht vertrauenswürdigen Quellen installiert, um das System zu schützen.
https://www-4waytechnologies-com.translate.goog/blog/3-easy-steps-to-install-third-party-apps-in-sam...
Kflamur
Thank you 👍
