09-09-2020 04:00 PM
I want to give voice commands, but the remote that came with the TV (just bought over Labor Day weekend) does not have a microphone. Every direction says "Press and Hold Mic." Where is the microphone on this remote? Thanks.
09-09-2020 04:41 PM
09-09-2020 04:58 PM
yes
09-09-2020 05:56 PM
09-09-2020 07:08 PM
Are you sure you’re tv has voice command. Looks like TU7000 doesn’t support voice command.
15-06-2024 06:37 PM
I also got a voice-assistant supported TV, the CU7000, but the remote has no mic.
