19-12-2023 03:03 PM
Only TV in the house that has these problems and I have tried it wireless and wired. If watching sports it buffers every 10 to 20 seconds to the point where it is not watchable.
is this just a junk TV?
Help....
19-12-2023 03:34 PM
19-12-2023 05:22 PM - last edited 19-12-2023 05:24 PM
@pinkstonm check you have the latest firmware, though it is a 2016 model.
A few additional things to try, hold the power Button for around 5 seconds until the Samsung logo displays and the Tv is restarted. check the streaming and if that does not work unplug the Tv for 5 minutes. with regards to wifi You could also change the channel on your router and possibly split the 2.4 and 5 Ghz as shown here https://support.accessagility.com/hc/should-i-use-different-ssids-for-2.4-ghz-and-5-ghz-bands-on-sam...
Sometimes it is necessary to change the DNS Settings,Go to Network-Network Settings-DNS Settings. Change from Automatic to to 8.8.8.8 or 8.8.4.4 (Google servers) An alternative is Open DNS 208.67.222.222 or 208.67.220.220
could also try a Factory Reset if mot attrmpted already.
