05-01-2018 05:11 PM in
TVHi all,
I purchased my Samsung UE49KS9000 last June but it did not included the TV spacers to mount in on the wall. I am trying to figure out now how I can mount the TV on my wall and I am really struggling to:
- firstly find out if they are really necessary for any wall mount
- if so, find what these spacers look like and buy spare ones online
- lastly get recommendations for the best (reasonably priced) wall mount that looks nice (no need for tilt version I just want one that makes the TV totally flat against the wall).
Thank you all for your help.
Best,
Felix
Solved! Go to Solution.
05-01-2018 07:58 PM in
TVDo you mean wall mount bolts? They are just to make sure you don't screw to far into the tv and damaged the display . Most good tv brackets come with them anyway but you have to make sure you don't screw to far . I have mine on the wall using the bolts that came with the tv but you don't have to use those .
06-01-2018 01:43 PM in
TVPerlegear bracket tv wall mount . It' on Amazon,I got the 37-70" one . The do have tilt and you can pull them about if you want . Honestly I have the same tv as you and it is great . You can just push it flat up the wall aswell ,well not flat obviously as the tv is curved . It has all the bolts you need .
06-01-2018 12:45 PM in
TVthank you Simon.
Called AVF who told me I need the Samsung spacers that came with the TV and they do not provide them and Samsung does not have spare ones.
Do you know of a good tv wall mount that has them?
09-02-2019 06:13 PM in
TVI have also lost my "Wall mount adapters" to my Samsung 75KS8005 TV. And I want to hang it on the wall? Where can I find spare parts? I do live in Sweden (Gothenburg). Anyone please?
01-06-2019 10:17 PM in
TV10-11-2020 02:16 PM in
TVI lost the special plastic adapters for mounting my Samsung TV when we moved. I found an acceptable replacement at Home Depot for $.56 each. They are SKU 595674, 0.312 ID x 1/2 OD x 1 in long.
