looking for: One Connect box : OCB - QE65Q7CAML
(Topic created on: 03-08-2023 03:53 PM)
KOtyrant
Hi there Samsung community,
As the subject suggest, I am in search of a OCB that works for the QE65Q7CAML.
I managed to get this tv through an auction, but it came without the OCB.
I've contacted Samsung through twitter, they informed I need to find BN91-19040D
I scoured google, but I hardly find any info on the item and SamsungParts informed that only this specific part will do.
I found a BN91-19040Z through ebay, which comes from a QE65Q7FAML, which is just the flat variant of the TV.
Sadly, I'm not eager to take a 150€ plunge in hope it'll just magically work.
Does any of you have had this product? Any chances you know if other OCB's will do the trick?
I appreciate any feedback.
Kind regards,
KO
0 REPLIES 0
