KU6670 corner too hot to touch and shadow on screen
(Topic created on: 21-09-2019 06:51 PM)
NickC77
Whilst watching our TV for about an hour we noticed a dark vertical shadow on the screen, when I went to investigate I noticed athe bottom right corner had developed a white spot. When I touched the corner it was unbeleivably hot and I am concerned it may melt the frame or worse burn one of my children. Has anyone else suffered this problem? The tv is about 4 years old.ml8+xsXOQWihY59BKRPjOg.jpg
5 REPLIES 5
AndrewL
@NickC77: Sorry to hear that you're having issues with your TV. Do you have any external devices connected to the TV such as a cable/satellite box or console? If so please unplug the devices to see if the issue persists. Furthermore please go to Settings > Support > Self Diagnosis > Picture Test to see if the shadowing or white spot is present in the test. If it is, I recommend reaching out to the Samsung AV Team on 0330 726 7864, or contacting a Support Centre to arrange an inspection. To find your nearest one please check the link below, select 'TV & AV > Television' and enter your post code.
http://www.samsung.com/uk/support/servicelocation/
NickC77
Thanks AndrewL. I have spoken to support and have been directed to my nearest service centre for inspection
TomF
Pathfinder
Thanks for the update! I'm positive the engineers at your nearest Support Centre will get this sorted for you.
FenKev
What was the out come? I have exactly the same issue, did they fix or was it a right off. Mine is 3 years old
NickC77
It was going to cost just to get it looked at and it was more than likely need a new screen which would cost a fortune so i used this as an excuse for a new TV.
